A SG5 for a mATX, it would work...
Edward78
233
So the Sugo SG5 is shoebox size... It is easy to carry around, great for lan parties... Wide as a SG1 (maybe a bit wider for a 5th slot for a double slot GPU to be in the last PCIe slot on the MB) anyway so you arn't limited by the smaller boards...
Regack
53
29
I used to have a Silverstone Sugo SG05, I think you'll be 20-30mm too narrow to fit a microATX board in there. I'm patiently waiting for the Kimera Nova.
6,591
SG05 is 222 mm wide. Minus 10mm or so for panel fitment and whatnot, even with modding you'd be limited to a 212mm board. Standard m-atx is 244x244mm.
