Introduction:
Hi everyone! This is a project I've been working on for a while now. It is heavily inspired by Henry.Z's Mk1 but houses a mini-STX motherboard and two 2.5 inch SATA drive. The chassis is designed to be holding something like a NAS or a download machine, which are likely not connected to a monitor and will be controlled remotely via AMT or other remote access programs.
Case details:
Height: 180mm
Length: 152mm (without stand)
Width: 56mm (without stand)
Volume: 1.53L
Material: Mainly consist of 13mm Aluminum and 3mm Aluminum panels
Side panel: 2mm acrylic or tempered glass
Hardware support:
Motherboard: Any current STX motherboard except Asus H110S2 due to the dual Ethernet port
CPU heatsink: Any heatsinks that are lower than 30mm in height. They will be cooled by 3 40mmx20mm fans located at the bottom of the case.
Hard drive: 2x 2.5inch SATA drive
GPU: N/A
Additional Information:
A 20x2 LCD/VFD screen can be mounted above the motherboard to display useful information such as temperature, downloading progress and much more. Any screen that can be recognized by AIDA64 can be used here.
That's all I have for now Since it is Chinese New Year now, I can't really have any prototype made. I will update this thread as design changes. Stay tuned for more!
Case details:
Height: 180mm
Volume: 1.53L
Hardware support:
GPU: N/A
