- Sep 24, 2016
- 518
- 631
Hello everyone,
I want to present a new concept that I've been working on. It builds on the awesome work of @Colinreay MK2 that he was so nice to open source. I initially wanted to build his exact case, but the lack of larger graphics card support bothered me a bit, especially after the latest generation of cards was introduced. So I went to the drawing table and altered the design so it could house most of the current cards.
The concept and design language stay the same: 2020 rounded aluminium extusions, laser cut panels and 3d printer parts. I changed the orientation of the graphics card to vertical while having the motherboard IO remain at the back of the case, similar to how the Velka 7 does. The only difference is that the parts are layed out so that the riser only needs a single bend and the case is quite a bit higher.
Without further ado, let's see how the case will actually look:
As for the hardware support:
- 47mm CPU cooler clearance
- SFX(L) PSU
- GPU thickness up to 60mm (3 slots) thick, as long as it has 1 or 2 slot PCI bracket
- GPU length limited to 325mm without top fan, 321mm with 15mm top fan, 311mm with 25mm top fan
- GPU height up to 150mm and an extra 16mm for power connectors
- Top mounted 120mm fan
- Up to 2 2.5inch drives up to 9mm thick
Currently, I've collected most hardware and I've been printing some of the parts already. I'm still waiting for the extrusions and my laser cutter to arrive, which can be any day now.
- SFX(L) PSU
