7L ish case recommendations for a fairly thicc gpu?
ThatGuy333333
24
Hey I’m looking at buying a case for my first itx build but I want to use my current gpu; gigabyte Vega 64 oc. Preferably something I could fit in a backpack easily, I don’t really have a preference of sandwich vs console style. But I can’t really spend that much on it so I’m looking at around the $150 range. Thanks.
KepKe
58
23
That card is triple slot right? Uff. To my knowledge, the smallest case volume vise to hold a triple slot + full length GPU should be the NCase M1 and the Sliger SM560, but both of them are above your price point and also larger with 11-12L.
If you had a dual slot GPU, you'd have a few more options at hand, such as the Dan A4, DrZaber Sentry Sliger SM550, ect. but they are all rather expensive, like a ll small volume cases end up being.
Maybe, the Lianli TU150 is something for you? It is a 23L case, but can hold pretty much your GPU and has a carry handle.
Reactions: Jello
ThatGuy333333
24
I’m gonna do some measurements on my gpu and see if a noctua fan swap will give me the extra 5 or so mm I need.
