So I just got my 646LT. I only tested it in a open bench and everything seems to be good. Before I installed to my case, after a double check I found something like liquid in the joint of both tubes. I wonder if anybody else has the same issue or can help me identify the problem. Thank you.
Edit: After reaching Asetek in reddit, it has been confirmed that this is lubricant from manufacture process, so I think it's safe to continue using it.
