Basically, I'm taking an Eclipse 1500C system, gutting it, integrating a laptop monitor (it just fits with some modding), putting a 8350K or 8600K and a 1070 Mini with a HDPlex 400W DC-ATX and an HDPlex brick.
The HDPlex DC-ATX will be in the case itself, which measures 351*213*62 at the base, the rear part is angled and is 351*240*62 at the top, which is equivalent to a volume of 4.92L.
The HDPlex power brick will reside in the bottom of the base, which is 210mm wide, so it's perfect. It'll be a brickless AIO computer! (don't think I can make this happen)
It'll have a standard 1366*768 monitor to start with until I can a find higher resolution alternative for cheap. Hoping for at least 1080p, would love 1080p/120hz, I think Alienware has some on some models of gaming laptops.
My biggest hurdle right now is to find an appropriate CPU cooler. I'll be using a Gigabyte Z370N-Wifi board and with a total height of 62mm, I don't know what CPU cooler height that equates to. The standoffs are like 5mm at most.
I hope I have your attention
HARDWARE
CPU : Intel i5 8600K
CPU cooler : Fanless Phanteks PH-TC12LS unless I can fit my Raijintek Pallas fanless.
Motherboard : Gigabyte Z370N-Wifi [Sponsored]
RAM : Team Group Nighthawk White 2*8GB 3600/18
SSD : Crucial MX200 500GB M.2
GPU : Gigabyte GTX 1070 Mini OC [Sponsored] with Li-Heat 30cm B-type riser and 3D Printed mount
PSU : HDPlex 400W HiFi DC-ATX [Sponsored] with HDPlex brick [Sponsored] mounted to the rear with 3D printed brackets
Monitor : integrated 15.6" 1366*768 (From Acer 5552 laptop) used as secondary display, haven't bought main display yet, either 32" 1440p 16:9 or 34" 1080p 21:9
Case : Eclipse 1500C with a few mods, case section measures approximately 345*230*62 (W*D*H) and has 7mm stand-offs for 4.99L The depth of case varies because the back is slanted, so 220 at the bottom and 240 at the top.
CUSTOM PARTS to do
3D printed front bezel replacement (printed in 6 parts!)
3D printed feet (4*)
HARDWARE
CUSTOM PARTS to do
