They're out there but they are not common! Prime H310T on Amazon. Also, Gigabyte has one with a PCIe slot but I have no clue where to buy one.
Thanks and I found this thing: https://www.asrock.com/ipc/overview.asp?Model=IMB-1212#Specification
Full x16!
Any idea where this can be purchased?
Full x16!
The Asrock IMB-1215 has Full 3.0x16 AND two (!) PCI 3.0 M.2 slots for storage. The only thing I worry about is the chipset on the backside, does that take any extra space, anybody know??
Darn. I guess that Gigabyte model with the X4 slot is the next best thing.
You found what in Canada...?
The IMB-1215 is much more expensive where I could find it: https://www.scan.co.uk/products/asr...m-sata3-dual-m2-2x-gbe-4x-com-usb31-g1-a-thin
