Attached are images of a current case I use:
I purchased this case from:
http://www.idotpc.com/thestore/pc/I...ackmount-Case-and-Bare-bone-Unit-148p1336.htm
I purchased it because it achieves several of my needs:
However, there a few things it gets wrong... VERY WRONG.
Firstly, and the biggest problem the case has is that it has FOUR hot-swappable hard drive trays. I only need a single hot-swap tray. Having four however, greatly limits the space inside the case. It makes cable management impossible, as you have to wrap the power cables around the back of the trays, which block the exhaust fan. Because of this, the case gets very hot. Instead of putting in four hot-swappable hard drive trays, they could have simply put in one 3.5" drive bay.
The case is made of steel. It's heavy... and gets very hot; yes, even the metal itself gets hot. The slim ODD tray is also a complete waste of space. They could have instead shifted some front panel connections, the USB ports, the LEDs and power button around and created more space for some cooling fans. Another bonus I could have used was more PCIe slots; so that I could possibly use a 8x/4x/4x bifurcated riser card.
So I guess my question would be... is someone out there willing to make a case that fits my needs?
- 2U rackable with removable handles
- Only 8 inches deep, so it fits in a very shallow rack
- Has 2 PCIe slots (which I use with a 8x/8x bifurcated riser)
- Has hot swappable hard drive trays.
