Not really sure this fits the bill as a "small form factor" PC. However, the box is pretty crammed with very little room left. This rig is my daily driver and performs quite well and doesn't make much noise after I volt-modded the water pump on that Fury X video card.
Sorry for the crappy pictures shot with my Xiaomi Mi A1.
It contains:
Gigabyte B350m mATX / Ryzen 1600x / Corsair AIO CPU cooler / 16GB / 512 m.2 / Fury X / BD-RE optical / 1000W PSU (total overkill)
It ended up like this because I had that 1kW PSU and the Fury X left over. Oh, and the original hardware from '98 had crapped out so the case was up for grabs. Drilled some holes for fans and cable management. The old CD-ROM and floppy drive now holds the slimline BD-RE and some USB ports.
As you can see the GPU's radiator is sucking in hot air from the CPU radiator. Not an optimal solution but I never see temps over 65C. The two lowest PCIe slots are holding a plate with room for two 2.5" drives. Not in use at the moment, I could theoretically fit another GPU, lol....
92mm in the rear, also some hand-drilled vents
The PSU is quite long and almost makes no room for that optical drive.
Hope you like or at least have a laugh!
It contains:
