Prototype 12.18L Dual 240AIO quite gaming PC case——Dual Cool MKII (4 months use report)
Tazpr
553
429
Friendly bump, interested to see pics, listed in TaoBao but can't really appreciate internals etc and if you will be retailing it in EU like you mentioned or KS.
It's already listed on TaoBao? Got a link?
WH-team
102
186
Hello everyone. About phurchase on TaoBao, It`s just a model exhibition. the 899 RMB isn`t final price. I will launch KICKSTARTER Crowd raising project for Dual Cool. And Material object phototype will coming soon!
WH-team
102
186
Update on Dual Cool is :
I will use all CNC build side panel, And it will have white/black two color to choose.
Graphic card is still "hand stand", It`s out put still in button of case. because now new graphic card like Readon vii or RTX 2080 all abandon OTES. So the card`s heat will divergence around instead regular in OTES radiator.
I add a new design in case structure:
the main structure——GPU and ITX MB bracket now could shift forward or back on the botton. so you could use AIO with fans if you don`t want use two AIO devices.
Perforated panel now is add in build plan.
Reactions: Alur
Alur
119
122
Those are great news, best of luck with KickStarter! I was worried you shutted down the project, looking forward to hit WarHead Team.
Skullassfreak
I wonder would 6 x 120mm fans be possible with 20mm XSPC tx rads. Maybe 4 slim fans (2 per rad) and 2 regular sized ones up top. With perforations on the side panel this would have the best cooling potential for this form factor. If theres not enough space for a pump/res, the swifttech pump/block combo and some qdc could be the solution.
WH-team
102
186
now if you could use 120 AIO you could get full 6*12025 fans intsall.
WH-team
102
186
Now new appearance had updated.
And there are some changed:
1:Now height has add 5mm-to 375mm
2:panel will use all CNC to make it
3:now 120AIO could install 6*121025 fans! It will be most powerfull airflow
4:Abandon button PCB design.Now you could use steering plug to use your devices. Like 90° DP line to link your monitors.
Alur
119
122
Pictures please WH Team! =)
Ricky
92
36
Looks good! As long as perforated panels remain an option, this case should go over very well with people.
Metroversal
224
492
@WH-team I don't know, judging from the looks it seems top-heavy, therefore unstable (it's just an impression).
Not a fan of not having a front I/O in a case with 12+ Liters volume.
Anyhow I like the new top grill design
Ricky
92
36
It’s based on an already existing concept though, the Corsair One.
Metroversal
224
492
Yes, I do get that. Specifically I was talking about how the bottom area is designed, I remember one Dan's C4 prototypes had similar issues. Anyhow I may be wrong, so don't take my word for it.
My point of not having front I/O still remains valid, even the Corsair One have plenty of ports on the front.
Ricky
92
36
Something I’ve been wondering. Would hybrid GPU’s work pretty well for this case?
WH-team
102
186
2019/8/5 the phototype finished
Metroversal
224
492
Nice looking prototype @WH-team !
Anyhow I still think this case should definitely have Front I/O. Also, how are you supposed to turn on the PC? Is the Power Button hidden somewhere?
I'n my humble opinion, your original idea was spot on!
Also, curious to see the perforated side panels!
