I have a concept (I took some inspiration from the NFC S4 Mini and Lazer3D HT5) for a highly customizable case designed for easy manufacturing by CNC and 3D printing.
There's two variants of this case. All front I/O is composed of keystones for maximum customizability. There will also be keystones on the rear, but I haven't yet modeled that. In addition, advanced owners could easily make their own front panels to accommodate the widest possible range of configurations.
There's also room for customization on the rear too. On the regular, there's a hole 40.5x162mm (will likely be changed), and the XL has an ATX PSU mount with an extra 10mm to the left. The small would likely have support for an adapter to mount either 2 additional expansion cards and a C14 inlet or a FlexATX PSU and some keystones, and the XL would have a bracket for 3 expansion slots and a C14 available. If you have a 3D printer, you'll be able to print brackets for whatever you can cram in there.
The small is 340mm wide, 320mm deep, and 100mm tall, resulting in 10.9L external volume and roughly 9.9L internal volume. You'll be able to comfortably mount an ITX motherboard, a 240mm radiator, a FlexATX PSU, and 4 slots of expansion cards, or an ATX motherboard, 3 expansion cards, slim slot load optical drive, FlexATX PSU, and air cooler up to 80mm tall. You can also use an SFX PSU, but there's constraints to keep in mind. If you use a Micro ATX motherboard, you will still be able to use all 4 expansion slots, but the lowermost one will be restricted to low profile cards.
The XL is 340mm wide, 340mm deep, and 150mm tall, resulting in 17.3L external volume and roughly 16.1L internal volume. You can comfortably fit an ATX motherboard, ATX power supply, slim slot load optical drive, 7 expansion cards, and 240mm radiator. The 3 expansion cards furthest from the CPU could be exchanged for a second 240mm radiator if you plan carefully, or you could use only the side radiator and fit an EATX board.
You'll notice the pictures show zero ventilation. I'm considering using SkySlots for it, but the licensing fee may be prohibitive, plus I'm not sure how well they'd work on acrylic panels. I may use powder coated aluminum panels instead, or even better have that available as an upgrade.
So, who's interested in this and what size? What would you put in it? What is it missing?
Small
I have a concept (inspired by the S4 Mini) for a highly customizable case designed for easy manufacturing by CNC or 3D printing.
There's three variants of this case. All front I/O is composed of keystones for maximum customizability. There's also keystones on the rear - 1 on the small, two on the medium, and 3 on the large. In addition, a front bezel is used to accommodate the widest possible range of configurations. If you have a 3D printer, you'll be able to print bezels and brackets for whatever you can cram in there.
All variants are 338mm wide x 322mm deep with a 314mm wide bezel. The smallest one is 54mm tall with a bezel height of 48mm and volume of 5.9L, medium is 74mm, 68mm, and 8.1L, and large is 94mm, 88mm, and 10.2L. The large version also has a rear bezel 147mm wide x 26mm tall.
You'll notice the pictures show zero ventilation (except for the rear bezel on the large case), and that's because I haven't modeled it yet. I'm considering using SkySlots for it, but I wanted to know if there's some kind of licensing fee?
Without further ado, let's get into the pictures and example configs:
So, who's interested in this and what version? What would you put in it? What is it missing?
