0.98L Ryzen 2400G/3600G Mini-STX Build
Discussion in 'Build Logs' started by chinevo, Mar 22, 2018.
  1. chinevo
    chinevo SFF Recordsman
    Thread Starter
    #1 chinevo, Mar 22, 2018
    confusis, Jonny727272 and sergiiua like this.
  2. ondert
    ondert Airflow Optimizer
    13mm cooler seems quite challenging.
  3. chinevo
    Thread Starter
    It’s not problem for me, I have expirience ;)
  4. ferdiptsy
    ferdiptsy Trash Compacter
    I'm very curious on any thin 13mm cooler concepts or actual apparatus. More specifically what kind of heatsink you're getting and modifying, because the fan is easy. I also wonder if it can handle the load or thermal throttle. What is your idea? Your "expirience"?
    Also, I think your IO dillemma is fixed by desoldering the ethernet-usb stuff, like a raspberry pi but that's all I know hueuhue.
    SeñorDonut likes this.
  5. chinevo
    Thread Starter
    #5 chinevo, Mar 23, 2018
    I plan to use single slot VGA cooler, something like this. Maybe I’ll make it by myself if I can't find right size.
    As for IO dillemma, yes, I’m going to desolder it :) I’ll use mini pci-e wifi adapter instead of ethernet port.
  6. Thehack
    Thehack Shrink Way Wielder
    Bronze Supporter Creator
    You'd have to downclock the APU a lot then. Those lil' things can only handle like 30-40W.
  7. chinevo
    Thread Starter
    Maybe yes, maybe not. I need to test it.
    1. This is GTX 750 card, that has 55W TDP. I read some reviews, max temp on full load is only 59C.
    2. I plan to delid APU.
    3. I don’t play in heavy games, only in CS:GO and Overwatch.
    But my priority is the world record :) I will downclock my APU If it is needed.
  8. thewizzard1
    thewizzard1 Cable-Tie Ninja
    You might be best off mounting the whole board on a single 5x5 block of aluminum / copper heatsink, with a rectangle cut into it for memory, and another for a fan. This will easily cool a 45W processor, with the lowest size possible.
    SFF EOL, jaruri, InfernoZeus and 4 others like this.
  9. RushNY
    RushNY SFF Gamer
    Perhaps a two-piece case with the top half used as a heatsink?
  10. chinevo
    Thread Starter
    Interesting, thanks. I’ll order it.
    Good option, I already have this aluminum heatsink and will try this solution.
    Maybe you can show some examples?
  11. CC Ricers
    CC Ricers SFF Guru
    Something like the Ocelot Cub?
    That is a cool design, and looks very doable from CNC milled aluminum. Too bad it was just a concept.
  12. ferdiptsy
  13. chinevo
    Thread Starter
  14. chinevo
    Thread Starter
    I chose CustomMOD (nano design) for implementing this project, now I’m just waiting for Asrock and their mobo.
  15. Jello
    Jello Airflow Optimizer
    Did Asrock even confirm they're making that motherboard, or are you just going off what they showed in the thread?
  16. chinevo
    Thread Starter
    Asrock haven’t confirmed that mobo yet.
  17. Windfall
    Windfall SFF Guru
    If they do, I have three cases ready for AMD stx: a 3.7L one that supports half height GPU's, a 1.2 L one that would run Igpu, and a 4L one that could handle a full GPU (all use hdplex) If AM4 STX happens, I'm dumping my current project.
  18. chinevo
    Thread Starter
    #19 chinevo, Apr 21, 2018
  19. chinevo
    Thread Starter
