Production сase series: SL1 2.1L; SL2 3.4L by Custom_MOD
sergiiua
CustomMOD
Jan 11, 2017
1,132
2,024
www.custom-mod.com
case SL5 mx 6.9L rev. 1.0 prototype (By purchasing this prototype you support us financially.)
Specs:
- Volume: 6.87L (321mm x 306mm x 70mm)
- Material: 1mm Steel, Powder Coating
- MB: mini-ITX (170x170mm)
- GPU: length <298mm, height <130mm < 42mm
- CPU Cooler: up to 55mm
- Storage: SSD/HDD: 3 x 2.5" 5-7mm
- PCIe x16 angle adapter
- PSU: SFX
sergiiua
CustomMOD
Jan 11, 2017
1,132
2,024
www.custom-mod.com
Reactions: ryandvd and ignsvn
sergiiua
CustomMOD
Jan 11, 2017
1,132
2,024
www.custom-mod.com
We are glas to inform you that we are resuming our work despite the war in Ukraine!As of now our means of production have been relocated to a safe place. Now we are able to ship our merchandise to USA, Europe and other countries with the exception of russia and Belarus
Visit our updated website
As for the SL2 3.4L case, I have prepared for you a new version.
  • Now all threaded connections have pressed-in nuts with larger threads.
  • The side walls of сase are now removable for easier installation.
  • The power button and USB connector are moved to the side panel.
sergiiua
CustomMOD
Jan 11, 2017
1,132
2,024
www.custom-mod.com
One experiment. I put the power supply on edge, and got a SL2 3.7L case. Now you can install more powerful processors and cool them with coolers up to 70mm!
  • Size: 228 x 183 x 88mm
  • Chassis supports 170 x 170mm mini-ITX motherboards
  • Use coolers to cool the CPU, no more than 70mm high.
  • Two 2.5" drives can be installed in a special basket
    *with the installed basket, coolers with a height of no more than 45mm are compatible.
  • You can also install one 2.5" drive without a cage.
    *maximum cooler height with this installation is no more than 60mm
  • The chassis is compatible with flex power supplies 1U
Page on the site
Reactions: Varoova
mike349
43
40
Hey! You have nice cases!
Wanted to ask - are there any plans to add USB Type-C and USB 3.0 to front/side panel ?
sergiiua
CustomMOD
Jan 11, 2017
1,132
2,024
www.custom-mod.com
Yes, I add such connectors according to the needs of customers. When ordering, you can specify which ones you need and I will try to find suitable ones and install them.
Reactions: Arboreal
sergiiua
CustomMOD
Jan 11, 2017
1,132
2,024
www.custom-mod.com
I assembled a PC in a mini SL2 3.7L case for programming
MB: mini-ITX #ASUS #STRIX B650E-I
CPU: AMD #RYZEN 5 7600X
Cooler: ID-COOLING IS-55
FAN: #NOCTUA NF-A12x15 #chromax
RAM: #DDR5 FURY 32Gb
Storage: NVMe #SAMSUNG 980 PRO
PSU: flex 1U #FSP #flexGURU300
Reactions: Quigonjinn
