Skyreach 4 MINI Vertical Case Stand
.STEP Skyreach 4 MINI Vertical Case Stand 2019-09-15
A 3D printable vertical case stand for the Skyreach 4 MINI case from NFC. There are two versions. The "Slim Version" is for the standard case dimensions. The "Wide Version" is for the 5mm extension to each side panel as seen in the build log at the link below. This was designed to be used with the machined aluminum case feet from NFC while providing airflow, but I imagine that any case feet can also be used. There are matching "gaskets" that can be 3D printed from a soft/flexible filament to provide a grip, and to prevent scratches to the bottom of the case.
Author
seven7thirty30
Downloads
26
Views
3,497
First release
Last update
Rating
0.00 star(s) 0 ratings
