Noctua bracket for LGA 2011 Narrow ILM
Other Noctua bracket for LGA 2011 Narrow ILM 1
Bracket to allow mounting Noctua heatsinks to the ASRock X99E-ITX/ac
Recommended only for heatsinks with the spring-loaded mounting screws (so not the original NH-L12)
Most any decent sheet metal shop can make these. I had mine made in 6061 aluminium but steel would work too. Stainless steel will probably need the pressed-in standoff changed to the stainless version.
The design (PDF and STEP files) are licensed under a CC0 1.0 Universal (CC0 1.0)Public Domain Dedication license. Basically you can use the file for whatever purpose you want (including commercial use) with no need to attribute (though giving credit would be appreciated).
Author
Downloads
52
Views
3,945
First release
Last update
Rating
0.00 star(s) 0 ratings
More resources from jeshikat
