FormD T1 v2 PSU Mount
.STEP FormD T1 v2 PSU Mount 2
This is a parasolid of the bracket I made to improve the dodgy stock FormD PSU bracket. This version does not require the extra deep slot in the front panel that I made in my "V1" version, I dont think it needs it or the M3 grubscrew I added also. The rigidness of the bracket, and the length or the tab in the slot does a good job.
Bear in mind this is for a 2.5-3.25 slot setup. For less slots youll need to shorten the tab.
Author
Jafa_NZ
Downloads
63
Views
2,824
First release
Last update
Rating
0.00 star(s) 0 ratings
