Resource icon
.STEP 5.5/2.5mm to panel mount Mini/Power DIN DC jack adapter 1
This adapter allows mounting a 5.5/2.5 mm DC jack (with M8 size threaded barrel), using the same mounting hole as a panel mount DC Power DIN jack would be mounted (eg. KPJX-PM).
The adapter design is based off of the KPJX-PM housing. An alternative design could eliminate the nut for the DC jack, and use a threaded housing.
Author
Lone
Downloads
Views
1,413
First release
Last update
Rating
0.00 star(s) 0 ratings
More resources from Lone
Latest updates
  1. Add SKP file
    Add SketchUp file.
